Einleitung
This guide will teach you how to replace the battery on your Alienware Area-51m. However, this guide is only for the person who have strong hands-on ability. If you think you cannot handle this work please find professional repair company. We are not responsible for any mistake or damage when you try to repair your computer.
Was du brauchst
Turn off the laptop and remove all the cables connected to your laptop.
Place the back of the laptop up.
Remove the six 8mm screws from the back cover using a Phillips #0 screwdriver.
Remove the battery cable from the motherboard.
Remove the six 5 mm screws holding down the battery using a Phillips #0 screwdriver.
Insert translation here
Put the new battery back and connect the battery cable to the motherboard.
Replace the six 5mm screws using a Phillips #0 screwdriver.
When reassembling your device, follow the instructions in reverse order.
100%
Austin Blakely hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
