Zum Hauptinhalt wechseln
Alienware Aurora A5 SSD Replacement
Was du brauchst
  1. Alienware Aurora A5 SSD Replacement, SSD: Schritt 1, Bild 1 von 2 Alienware Aurora A5 SSD Replacement, SSD: Schritt 1, Bild 2 von 2
    • Power off the computer.
    • To ensure the PC is completely off, remove the cables at the back of the PC.
  2. Alienware Aurora A5 SSD Replacement: Schritt 2, Bild 1 von 3 Alienware Aurora A5 SSD Replacement: Schritt 2, Bild 2 von 3 Alienware Aurora A5 SSD Replacement: Schritt 2, Bild 3 von 3
    • Lift the black latch at the back of the PC to pop open the side cover.
    • Carefully remove the side cover by lifting it up.
  3. Alienware Aurora A5 SSD Replacement: Schritt 3, Bild 1 von 2 Alienware Aurora A5 SSD Replacement: Schritt 3, Bild 2 von 2
    • Unlock both tabs on the back of the PC by pushing them up.
    • Remove the power supply latch to get access to the inside.
  4. Alienware Aurora A5 SSD Replacement: Schritt 4, Bild 1 von 3 Alienware Aurora A5 SSD Replacement: Schritt 4, Bild 2 von 3 Alienware Aurora A5 SSD Replacement: Schritt 4, Bild 3 von 3
    • Remove the black plastic part by pushing it down and then pulling it towards you.
    • Unlock the blue latch and pull to remove the graphics card.
  5. Alienware Aurora A5 SSD Replacement: Schritt 5, Bild 1 von 3 Alienware Aurora A5 SSD Replacement: Schritt 5, Bild 2 von 3 Alienware Aurora A5 SSD Replacement: Schritt 5, Bild 3 von 3
    • Use the Phillips #1 screwdriver to remove the 3.7 mm screw and remove the old M2 SSD.
Abschluss
Ensure that you tightly screwed on the M2 SSD and that you inserted the graphics card back to its position so that the PC runs smoothly with no problems. Once you have completed all the steps and reconnected the cables you have successfully replaced the NVMe M2 SSD and your PC is ready to be turned on!
4 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team S1-G17, O'Regan Summer 2021 Mitglied von York University, Team S1-G17, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G17
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 21
Letzte 30 Tage: 146
Insgesamt: 1,402
