Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Use this guide to replace the camera on your Alienware Aurora M9700. Be sure to power off the computer and disconnect from any external power source before beginning the camera replacement. Care should be taken when removing the display frame from the computer screen since it is very fragile.
  1. Open the device so the main screen is facing forward.
    • Open the device so the main screen is facing forward.
    • Locate the 8 rubber buttons around the bezel of the display and remove the rubber buttons with the metal spudger to expose the screws underneath.
    • Locate the 8 screws around the perimeter of the screen and unscrew them.
  2. Insert the plastic opening tool between the black and green frames to remove the display frame at the bottom of the display. Slide the lock to the right when removing the display frame,
    • Insert the plastic opening tool between the black and green frames to remove the display frame at the bottom of the display.
    • Slide the lock to the right when removing the display frame,
    • Remove the frame display.
  3. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  4. Now that the outer frame is removed, locate the two screws to the right and the left of the camera. Remove the two screws freeing the camera of the brackets holding it in place.
    • Now that the outer frame is removed, locate the two screws to the right and the left of the camera.
    • Remove the two screws freeing the camera of the brackets holding it in place.
    • Pry the camera upward from its designated location using the metal spudger.
  5. Unplug the wire connection between the camera and the laptop. Unplug the wire connection between the camera and the laptop.
    • Unplug the wire connection between the camera and the laptop.
Abschluss
Jasmine Anchondo
661 Reputation
5 Anleitungen geschrieben
Sam Houston State, Team S15-G3, Blackburne Fall 2018 Mitglied von Sam Houston State, Team S15-G3, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G3
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 94
