Zum Hauptinhalt wechseln
Alienware Aurora M9700 Hard Drive Replacement
Was du brauchst
  1. Alienware Aurora M9700 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Turn laptop upside down so you're looking at the bottom side of the laptop.
  2. Alienware Aurora M9700 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Alienware Aurora M9700 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Alienware Aurora M9700 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • At the bottom left corner, locate the square battery pack with the sliding unlock emblem above it.
    • Slide the lock to the right to unlock the battery pack.
    • Once it's unlocked the battery will release.
    • Lift the battery, removing it from its compartment.
  3. Alienware Aurora M9700 Hard Drive Replacement: Schritt 3, Bild 1 von 3 Alienware Aurora M9700 Hard Drive Replacement: Schritt 3, Bild 2 von 3 Alienware Aurora M9700 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • At the bottom right corner, locate the two hard drives labeled 1 and 2.
    • Remove the screws located on top of the hard drives slots.
    • Once screws are removed from each hard drive, slide both hard drives out of the slot.
  4. Alienware Aurora M9700 Hard Drive Replacement: Schritt 4, Bild 1 von 3 Alienware Aurora M9700 Hard Drive Replacement: Schritt 4, Bild 2 von 3 Alienware Aurora M9700 Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Each hard drive is attached to a cover which contains 4 screws located on all 4 corners of the hard drive.
    • Remove each of the 4 screws on both hard drive covers.
    • Once both covers are removed only the original hard drive will remain.
  5. Alienware Aurora M9700 Hard Drive Replacement: Schritt 5, Bild 1 von 3 Alienware Aurora M9700 Hard Drive Replacement: Schritt 5, Bild 2 von 3 Alienware Aurora M9700 Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Secure the new hard drive to the original hard drive cover, insert the screws on all 4 corners of the hard drive cover.
    • Complete this process for both hard drives. (Optional: if installing two drives.)
Abschluss
Sam Houston State, Team S15-G3, Blackburne Fall 2018 Mitglied von Sam Houston State, Team S15-G3, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 405
