Einleitung
In this guide, we will be showing you how to remove and replace the Display Assembly.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Loosen the two captive screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, pull the hard-drive assembly to disconnect the hard-drive assembly from the connector on the system board.
Lift the hard-drive assembly out of the computer base.
Remove the four screws that secure the hard drive to the hard-drive bracket.
Replace the four screws that secure the hard-drive to the hard-drive bracket.
Use the pull-tab to push the hard drive assembly and connect it to the connector on the system board.
Tighten the two captive screws that secure the hard-drive assembly to the computer base.
2 weitere Nutzer haben diese Anleitung absolviert.
