Zum Hauptinhalt wechseln
Alienware M11xR2 Base Cover Replacement
Was du brauchst
  1. Alienware M11xR2 Base Cover Replacement, Removing the Base Cover: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Base Cover Replacement, Loosen the Screws: Schritt 2, Bild 1 von 1
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Base Cover Replacement, Lifting the Base Cover: Schritt 3, Bild 1 von 1
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Base Cover Replacement, Replacing the Base Cover: Schritt 4, Bild 1 von 1
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Base Cover Replacement, Securing the Screws: Schritt 5, Bild 1 von 1
    • Tighten the eight screws that secure the base cover to the computer base.
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
darrius
5.213 Reputation
30 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.991 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 451
