Zum Hauptinhalt wechseln
Alienware M11xR2 Battery Pack Replacement
Was du brauchst
  1. Alienware M11xR2 Battery Pack Replacement, Removing the Base Cover: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Battery Pack Replacement, Loosen the Screws: Schritt 2, Bild 1 von 1
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Battery Pack Replacement, Lifting the Base Cover: Schritt 3, Bild 1 von 1
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Battery Pack Replacement, Replacing the Base Cover: Schritt 4, Bild 1 von 1
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Battery Pack Replacement, Securing the Screws: Schritt 5, Bild 1 von 1
    • Tighten the eight screws that secure the base cover to the computer base.
  6. Alienware M11xR2 Battery Pack Replacement, Removing Screws: Schritt 6, Bild 1 von 1
    • Remove the two screws that secure the battery pack to the computer base.
  7. Alienware M11xR2 Battery Pack Replacement, Disconnecting cable: Schritt 7, Bild 1 von 1
    • Disconnect the battery pack cable from the connector on the system board.
  8. Alienware M11xR2 Battery Pack Replacement, Lifting Battery Pack: Schritt 8, Bild 1 von 1
    • Using the pull-tab, lift the battery pack off the computer base.
  9. Alienware M11xR2 Battery Pack Replacement, Placing New Battery Pack: Schritt 9, Bild 1 von 1
    • Place the NEW battery pack in the battery bay and replace the two screws that secure the battery pack to the computer base.
  10. Alienware M11xR2 Battery Pack Replacement, Routing Battery Pack: Schritt 10, Bild 1 von 1
    • Route the battery pack cable in the routing guide
  11. Alienware M11xR2 Battery Pack Replacement, Connnecting Battery Pack: Schritt 11, Bild 1 von 1
    • Connect the battery pack cable to the connector on the system board.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
darrius
5.213 Reputation
30 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 235
