Zum Hauptinhalt wechseln
Alienware M14xR2 Optical Drive Replacement
Was du brauchst
  1. Alienware M14xR2 Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Optical Drive Replacement: Schritt 2, Bild 1 von 3 Alienware M14xR2 Optical Drive Replacement: Schritt 2, Bild 2 von 3 Alienware M14xR2 Optical Drive Replacement: Schritt 2, Bild 3 von 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Optical Drive Replacement: Schritt 3, Bild 1 von 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Optical Drive Replacement: Schritt 4, Bild 1 von 3 Alienware M14xR2 Optical Drive Replacement: Schritt 4, Bild 2 von 3 Alienware M14xR2 Optical Drive Replacement: Schritt 4, Bild 3 von 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Optical Drive Replacement, Optical Drive: Schritt 5, Bild 1 von 3 Alienware M14xR2 Optical Drive Replacement, Optical Drive: Schritt 5, Bild 2 von 3 Alienware M14xR2 Optical Drive Replacement, Optical Drive: Schritt 5, Bild 3 von 3
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 13-4, Forte Fall 2013 Mitglied von Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 2,719
