Einleitung
Use this guide for help on removing the compartment door. This is necessary for other replacement guides such as the GPU and the hard drive.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the battery by sliding the latch to the left and pulling the battery up. Remove the battery by sliding the latch to the left and pulling the battery up. Remove the battery by sliding the latch to the left and pulling the battery up.
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip. Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  4. Slide the compartment door towards the front of the computer and lift. Slide the compartment door towards the front of the computer and lift. Slide the compartment door towards the front of the computer and lift.
    • Slide the compartment door towards the front of the computer and lift.
Abschluss
Jake Alexander
85 Reputation
1 Anleitung geschrieben
Cal Poly, Team S11-G3, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 93
