Zum Hauptinhalt wechseln
Alienware M15x Hard Drive Replacement
Was du brauchst
  1. Alienware M15x Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Alienware M15x Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Alienware M15x Hard Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Alienware M15x Hard Drive Replacement, Compartment Door: Schritt 2, Bild 1 von 2 Alienware M15x Hard Drive Replacement, Compartment Door: Schritt 2, Bild 2 von 2
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  3. Alienware M15x Hard Drive Replacement: Schritt 3, Bild 1 von 3 Alienware M15x Hard Drive Replacement: Schritt 3, Bild 2 von 3 Alienware M15x Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Slide the compartment door towards the front of the computer and lift.
  4. Alienware M15x Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Use Phillips #1 screwdriver to loosen the four screws on the hard drive enclosure.
  5. Alienware M15x Hard Drive Replacement: Schritt 5, Bild 1 von 2 Alienware M15x Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Once the screws are loosened use the "PULL" tab to remove the current hard drive from the computer.
  6. Alienware M15x Hard Drive Replacement: Schritt 6, Bild 1 von 2 Alienware M15x Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Remove the four small screws indicated to remove the casing to the hard drive.
  7. Alienware M15x Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Now take off the SATA converter and then connect it to the drive you would like to replace it with.
Abschluss
David Sann
111 Reputation
1 Anleitung geschrieben
Cal Poly, Team S11-G3, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 835
