Zum Hauptinhalt wechseln
Alienware M15x Hard-Drive Replacement
Was du brauchst
  1. Alienware M15x Hard-Drive Replacement, Turn the Computer: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • Turn the computer over.
  2. Alienware M15x Hard-Drive Replacement, Sliding the Battery: Schritt 2, Bild 1 von 1
    • Slide the battery latch to the unlock position as shown.
  3. Alienware M15x Hard-Drive Replacement, Removing the Battery Pack: Schritt 3, Bild 1 von 1
    • After the Battery Pack pops up, remove the Battery Pack.
  4. Alienware M15x Hard-Drive Replacement, Aligning the Battery Pack Tabs: Schritt 4, Bild 1 von 1
    • Align the battery pack tabs with the slots in the battery bay.
  5. Alienware M15x Hard-Drive Replacement, Pushing the Battery Pack: Schritt 5, Bild 1 von 1
    • Push the NEW battery pack into the battery bay until the battery pack clicks into place.
  6. Alienware M15x Hard-Drive Replacement, Loosen the Screws: Schritt 6, Bild 1 von 1
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • Loosen the four captive screws that secure the hard-drive assembly.
  7. Alienware M15x Hard-Drive Replacement, Lifting the Hard-Drive Assembly: Schritt 7, Bild 1 von 1
    • Using the pull-tab, lift the hard-drive assembly out of the hard-drive bay.
  8. Alienware M15x Hard-Drive Replacement, Remove the Screws: Schritt 8, Bild 1 von 1
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  9. Alienware M15x Hard-Drive Replacement, Lifting the Hard Drive: Schritt 9, Bild 1 von 2 Alienware M15x Hard-Drive Replacement, Lifting the Hard Drive: Schritt 9, Bild 2 von 2
    • Lift the hard drive out of the hard-drive bracket.
  10. Alienware M15x Hard-Drive Replacement, Disconnect the Interposer: Schritt 10, Bild 1 von 2 Alienware M15x Hard-Drive Replacement, Disconnect the Interposer: Schritt 10, Bild 2 von 2
    • Disconnect the interposer from the hard drive.
  11. Alienware M15x Hard-Drive Replacement, Connecting the Interposer: Schritt 11, Bild 1 von 2 Alienware M15x Hard-Drive Replacement, Connecting the Interposer: Schritt 11, Bild 2 von 2
    • Connect the interposer to the NEW hard drive.
  12. Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive in the Bracket: Schritt 12, Bild 1 von 2 Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive in the Bracket: Schritt 12, Bild 2 von 2
    • Place the hard drive in the hard-drive bracket.
  13. Alienware M15x Hard-Drive Replacement, Replace the Four Screws: Schritt 13, Bild 1 von 1
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  14. Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive Assembly: Schritt 14, Bild 1 von 1
    • Place the hard-drive assembly in the hard-drive bay.
  15. Alienware M15x Hard-Drive Replacement, Aligning and Tightening the Screws: Schritt 15, Bild 1 von 1
    • Align and tighten the four captive screws that secure the hard-drive assembly to the hard-drive bay.
Abschluss
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 482
