Einleitung
This guide will explain how to carefully and safely remove the RAM from an Alienware M15x laptop.
Was du brauchst
Remove the battery by sliding the latch to the left and pulling the battery up.
Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
Push the two retaining clips on either side of the ram outwards, allowing the RAM chip to pop up.
Fast fertig!
Abschluss
