Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Upgrade your RAM for an instant increase in speed.
The M15x uses DDR3 1333MHz memory.
  1. First, take off the battery by moving the latch to the left and pulling it up.
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Then unscrew the two Phillips screws. Pull the cover down, then up, revealing the internals Pull the cover down, then up, revealing the internals
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. EINFACH ALLE TABS ÖFFNEN
    RAM Upgrade Kits für Mac
    Kits kaufen
    Genügend RAM
    für alle Tabs
    Kits kaufen
  4. Unscrew the two screws indicated
    • Unscrew the two screws indicated
  5. Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
Abschluss
6 weitere Nutzer haben diese Anleitung absolviert.
Gabe
8.208 Reputation
3 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
294 Mitglieder
950 Anleitungen geschrieben
I saw somewhere that it actually takes DDR2 ram not DDR3....
John Moreau - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 2
Letzten 7 Tage: 2
Letzten 30 Tage: 4
Insgesamt: 24,048
