Zum Hauptinhalt wechseln
Alienware M17-R1 RAM Replacement
Was du brauchst
  1. Alienware M17-R1 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 RAM Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 RAM Replacement, RAM: Schritt 3, Bild 1 von 1
    • Place laptop down on a hard flat surface to begin the disassembly.
  4. Alienware M17-R1 RAM Replacement: Schritt 4, Bild 1 von 2 Alienware M17-R1 RAM Replacement: Schritt 4, Bild 2 von 2
    • Remove the nine 3 mm screws that secure the cover using a Phillips #1 screwdriver.
  5. Alienware M17-R1 RAM Replacement: Schritt 5, Bild 1 von 1
    • Once the cover is removed, locate the RAM compartment to begin the replacement.
  6. Alienware M17-R1 RAM Replacement: Schritt 6, Bild 1 von 2 Alienware M17-R1 RAM Replacement: Schritt 6, Bild 2 von 2
    • After locating the RAM, gently pull the two metal clips outward and lift the RAM card out of its socket.
    • The card will pop up once it has been released and can be removed.
  7. Alienware M17-R1 RAM Replacement: Schritt 7, Bild 1 von 1
    • To insert the new RAM, place it on top of the socket and carefully apply downward pressure until it snaps into place.
Abschluss
LXA054
337 Reputation
3 Anleitungen geschrieben
Sam Houston State, Team S15-G2, Blackburne Fall 2018 Mitglied von Sam Houston State, Team S15-G2, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 667
