Einleitung
If your battery can't keep a charge or drains quickly, use this guide to remove and replace your battery.
Was du brauchst
Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
Slide cover forward then carefully lift up.
Carefully use the Plastic Opening Tool to unplug the battery.
Lift the battery up and out to remove.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
