Zum Hauptinhalt wechseln
Alienware M17x Hard Drive Replacement
Was du brauchst
  1. Alienware M17x Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Alienware M17x Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Alienware M17x Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
  3. Alienware M17x Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
  4. Alienware M17x Hard Drive Replacement: Schritt 4, Bild 1 von 2 Alienware M17x Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
  5. Alienware M17x Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • With the laptop flipped over, cover removed, and battery removed; continue by locating your hard drive(s).
  6. Alienware M17x Hard Drive Replacement: Schritt 6, Bild 1 von 3 Alienware M17x Hard Drive Replacement: Schritt 6, Bild 2 von 3 Alienware M17x Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Remove the eight 3.5 mm Phillips #0 screws.
    • Remove the hard drive(s), using the Plastic Opening Tool by lifting on the edges and pulling the hard drive up and out.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 2,357
