Einleitung
Is your computer not loading application properly? Consider using this guide to replace the RAM in your laptop.
Was du brauchst
Press down on the battery latch and slide it to the left.
Lift the battery out once it pops out.
Remove the Phillips #1 screw holding the plate.
Use your hand to remove the plate.
Pull the clips to the side away from each other. The RAM will pop up.
Lift forward and gently loosen to pull out of socket.
For the second RAM card use the opening tool to gently lift the RAM card forward.
2 weitere Personen haben diese Anleitung absolviert.
