Einleitung
If your RAM can't keep up with the demands of today's mundane and daily tasks, use this guide to remove and replace your RAM cards.
Was du brauchst
Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
Slide cover forward then carefully lift up.
Carefully use the Plastic Opening Tool to unplug the battery.
Lift the battery up and out to remove.
With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards.
Remove the top RAM card by pressing the tabs to the sides using the Plastic Opening Tool.
Once the top card has popped up, carefully remove it by holding the sides and sliding it out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
The only problem is that this laptop has 4 slots of ram there are 2 more under the keyboard that must also be accessed to update. If anyone wants to know how I know it’s because I have this laptop and I have seen where the next lot of ram is located
