Einleitung
This guide illustrates the steps needed to locate, remove, and replace the CD drive in an Alienware M18x gamer laptop.
Ersatzteile
Keine Ersatzteile angegeben.
Turn the computer over.
Slide the battery latch over and lift the battery out.
Turn the laptop right-side up, and open the laptop.
Use the plastic pryer tool to loosen the flat piece surrounding the keys by gently prying it upwards from the laptop's base.
Make sure to go around the entire perimeter of the piece to loosen all areas of it.
The piece is now free from its fastenings to the base of the laptop, and can be lifted off.
Gently remove the power cable with your hands or with the help of a prying tool.
The keyboard's 3mm fastening screws are now exposed and can be removed with a J000 screwdriver.
As before, the keyboard is now unfastened but still connected to the base via cables.
Flip the keyboard over towards the edge of the laptop to expose the locations of the connectors. Avoid tugging on the cables when you do this.
The left section of the keyboard is connected by a single screw and two connector cables.
Remove the 4mm screw with a J000 screwdriver.
Remove the connecting cables with a prying bar.
Place computer face up.
Locate the connecting tab holding the top section of the laptop in place.
Using needle nose pliers, disconnect the tab.
Carefully lift up on the panel to access the internal components.
Locate the blue USB board. This board covers the CD Drive.
Find the edges of each card holder and gently pull each out of their socket.
Remove the screws retaining the USB port board with a screwdriver.
Disconnect orange tab to free board of all connections.
Lift up on the board for access to CD Drive.
Remove the four 3mm screws from the CD Drive housing.
Disconnect the thin end of the orange connector from the motherboard. It should still be connected to the CD Drive at one end.
Remove the CD drive gently from the laptop.
