Einleitung
There are three internal fans located in the Alienware M18x laptop. This guide will demonstrate how to go about removing said fans.
Was du brauchst
Turn the computer over.
Slide the battery latch over and lift the battery out.
The fan will be connected to the motherboard by a cable. Use plastic tweezers to gently unplug this connection.
The fan is now fully disconnected from the computer. Gently remove the fan by lifting upwards.
