Einleitung
Batteries fail from heat and if they reach their max charge cycles limit. This guide will show you how to replace it.
Was du brauchst
Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
Using PH1 screwdriver loosen the two screws on the right of the battery.
2 weitere Personen haben diese Anleitung absolviert.
