Zum Hauptinhalt wechseln
Alienware P18G M14X R1 Hard Drive Replacement
Was du brauchst
  1. Alienware P18G M14X R1 Hard Drive Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 Hard Drive Replacement, Battery: Schritt 4, Bild 1 von 1
    • Make sure the laptop is turned off before starting.
    • Using PH1 screwdriver loosen the two screws on the right of the battery.
    • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
  5. Alienware P18G M14X R1 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Alienware P18G M14X R1 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Pull battery up using the tab provided.
  6. Alienware P18G M14X R1 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the clip connecting the battery to the computer.
    • Set battery aside.
  7. Alienware P18G M14X R1 Hard Drive Replacement, Optical Drive: Schritt 7, Bild 1 von 1
    • Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
  8. Alienware P18G M14X R1 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Using the plastic opening tool unclip the white connector holding down the orange cable.
  9. Alienware P18G M14X R1 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
  10. Alienware P18G M14X R1 Hard Drive Replacement, Hard Drive: Schritt 10, Bild 1 von 1
    • Loosen the three 6.35 mm screws using the PH1 screw driver, to release the hard drive.
    • The screws will not be able to be removed from the hard drive. They can only be loosened or tightened.
  11. Alienware P18G M14X R1 Hard Drive Replacement: Schritt 11, Bild 1 von 1
    • Pull the tab on the hard drive slowly and carefuly because there will be a cable attached to it.
  12. Alienware P18G M14X R1 Hard Drive Replacement: Schritt 12, Bild 1 von 1
    • Pull the clip away from the hard drive to remove it.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team S2-G2, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S2-G2, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G2
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 29
Insgesamt: 2,920
