Einleitung
In order to remove the RAM you first need to remove the battery.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Slide back cover forward using your thumbs.
    • Slide back cover forward using your thumbs.
    • Lift up the cover and set aside exposing the internals of the computer.
    • Unscrew the two 6.35 mm using the PH1 screw driver.
    • Lift the plate and remove it to uncover the RAM sticks.
    • Push outward on the prongs that secure the RAM stick in the slots.
    • After releasing the prongs the rams stick will rise up.
    • Be very gentle in this step, making sure to not damage anything.
    • Pull the RAM stick out of its housing.
    • Pull the second ram stick out of its housing.
Abschluss
Andonaq Grozdani
Mitglied seit 01.03.2018
718 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S2-G2, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S2-G2, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G2
3 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 103
