Zum Hauptinhalt wechseln
Alienware X51 Heatsink Replacement
Was du brauchst
  1. Alienware X51 Heatsink Replacement, Front Panel: Schritt 1, Bild 1 von 1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Heatsink Replacement: Schritt 2, Bild 1 von 1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Heatsink Replacement, Fan: Schritt 3, Bild 1 von 2 Alienware X51 Heatsink Replacement, Fan: Schritt 3, Bild 2 von 2
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
  4. Alienware X51 Heatsink Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the Molex KK connector from the fan.
  5. Alienware X51 Heatsink Replacement: Schritt 5, Bild 1 von 3 Alienware X51 Heatsink Replacement: Schritt 5, Bild 2 von 3 Alienware X51 Heatsink Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
  6. Alienware X51 Heatsink Replacement, Heatsink: Schritt 6, Bild 1 von 3 Alienware X51 Heatsink Replacement, Heatsink: Schritt 6, Bild 2 von 3 Alienware X51 Heatsink Replacement, Heatsink: Schritt 6, Bild 3 von 3
    • Loosen the four 10.0 mm screws around the heatsink with a Phillips #1 screwdriver until you hear a click.
    • These are captive screws and cannot be fully removed.
    • Remove the heatsink by gently prying and lifting it up.
Abschluss
alondra
123 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 78
