Einleitung
The Alienware X51 R1, R2, and R3 shut down randomly when a computer's RAM starts to fail. This can be problematic with wear but is easy to fix with basic tooling. Before beginning the repair, a user must have a Phillips-head screwdriver and two eight-gigabyte RAM memory cards for a total of sixteen gigabytes.
NOTE: use an anti-static wrist strap when working to prevent circuitry damage.
Was du brauchst
Place the PC so the name "Alienware" is on top and facing you.
Slide the front panel towards you and lift up.
Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
Remove the front panel from the rest of the device.
Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
Remove the protector holding the fan in.
Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
Gently pull back the clips and remove the fan by pulling it out.
Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
Remove the disc drive from the PC.
Pull apart the clips that hold the RAM sticks in place.
Remove the RAM sticks.
