Einleitung
Prerequisites 1. Follow the procedure in Before working inside your computer.
Was du brauchst
Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
Lift the base cover off the palm-rest and keyboard assembly.
Disconnect the battery cable from the system board.
Turn your computer over and press the power button for 20 seconds to drain the flea power
Remove the two screws (M2x4) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
Remove the two screws (M2.5x5) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
Disconnect the Tron light cable from the system board.
Firmly grasp the sides of your computer with both hands and push the rubber feet on the rear I/O-cover outwards with yourthumbs to release the rear I/O-cover from the palm-rest and keyboard assembly.
Slide the rear I/O-cover away from the palm-rest and keyboard assembly.
Open the latch and disconnect the display cable from the system board.
Disconnect the Alienhead LED cable from the system board.
Disconnect the RGB-IR camera cable from the USB board.
Lift the system board Mylar and peel the tapes that secure the RGB-IR camera cable to the system board.
Lift the RGB-IR camera cable off the system board.
Turn the computer over and place the computer on a clean and flat surface.
Remove the display cable from the routing guides on the palm-rest and keyboard assembly.
Remove the RGB-IR camera cable from the routing guides on the palm-rest and keyboard assembly.
Remove the six screws (M2.5x5) that secure the display hinges to the palm-rest and keyboard assembly.
Lift the display assembly off the palm-rest and keyboard assembly.
Eine weitere Person hat diese Anleitung absolviert.
