Einleitung
The Alldaymall A88X has a 0.3 MP forward facing camera and a 2.0 MP rear facing camera. They are mounted on to the back panel. This guide will walk you through the process of removing the existing cameras and installing new ones.
Was du brauchst
Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
After the speaker has been removed, place the rear panel aside.
Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
Using a pair of tweezers, begin separating the tape downwards from the back panel.
Pull the tape away from the wire bundle beneath.
Isolate the wire running from the speaker to the motherboard.
Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
After the battery is separated from the panel make sure to place it face down above the tablet itself.
Using a pair of tweezers begin to peel the tape covering the ribbon cable on the motherboard.
Using a pair of tweezers begin to peel the antenna from the metal panel.
Work your way down until the antenna is completely removed.
Using a pair of tweezers remove the tape securing the cameras to the back panel.
Using a pair of tweezers remove the camera assembly from its housing and its receptacles.
