Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide teaches you how to remove the battery cover and batteries.
  1. Before attempting to remove batteries, make sure the device is turned off. Locate the battery compartment on the back of the AlphaSmart Pro. Push the tab inward and lift up. This will detach the cover from the device.
    • Before attempting to remove batteries, make sure the device is turned off.
    • Locate the battery compartment on the back of the AlphaSmart Pro.
    • Push the tab inward and lift up. This will detach the cover from the device.
  2. Remove each battery by using your fingers or the spudger to pry them from the compartment. Remove each battery by using your fingers or the spudger to pry them from the compartment.
    • Remove each battery by using your fingers or the spudger to pry them from the compartment.
Abschluss
Ashley Orr
109 Reputation
2 Anleitungen geschrieben
Clemson, Team 1-1, Benson Fall 2014 Mitglied von Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 177
