Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Ersatzteile
Keine Ersatzteile angegeben.
  1. Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly. Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver. Carefully separate the front panel from the back panel.
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. To remove the ribbon cable, use the spudger to lift each side of the connector from the socket. Gently pull up on the connector to completely remove the connector from the socket. Remove front panel from the motherboard.
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    • Remove front panel from the motherboard.
  3. Use the Phillips #00 Screwdriver to remove the four 1 cm screws from each corner of the keyboard. Gently lift the keyboard from the rear panel. Notice that the keyboard is still connected to the motherboard by two ribbon cables.
    • Use the Phillips #00 Screwdriver to remove the four 1 cm screws from each corner of the keyboard.
    • Gently lift the keyboard from the rear panel.
    • Notice that the keyboard is still connected to the motherboard by two ribbon cables.
  4. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  5. To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable. Pull the ribbon cable to remove it from the connector. Repeat the exact steps above for the other ribbon cable.
    • To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable.
    • Pull the ribbon cable to remove it from the connector.
    • Repeat the exact steps above for the other ribbon cable.
    • While the large connector on the left must be pulled toward you in order to remove the ribbon cable, the smaller connector on the right must be pushed away from you.
  6. Remove keyboard from motherboard.
    • Remove keyboard from motherboard.
  7. Flip the AlphaSmart Pro over so that the rear panel is facing upward. Using a spludger, carefully disconnect the battery prongs, located in the battery compartment.
    • Flip the AlphaSmart Pro over so that the rear panel is facing upward.
    • Using a spludger, carefully disconnect the battery prongs, located in the battery compartment.
  8. Using a Phillips #00 Screwdriver, remove the four 0.8 cm screws from the motherboard. Carefully lift the motherboard away from the rear panel.
    • Using a Phillips #00 Screwdriver, remove the four 0.8 cm screws from the motherboard.
    • Carefully lift the motherboard away from the rear panel.
Abschluss
Ashley Orr
109 Reputation
2 Anleitungen geschrieben
Clemson, Team 1-1, Benson Fall 2014 Mitglied von Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 269
