Zum Hauptinhalt wechseln
Alpine Ski Wax Application
Was du brauchst
  1. Alpine Ski Wax Application, Alpine Ski Wax Application: Schritt 1, Bild 1 von 1
    • Attach heavy rubber bands around the brakes.
  2. Alpine Ski Wax Application: Schritt 2, Bild 1 von 1
    • Spray base cleaner along the bottom of the ski.
  3. Alpine Ski Wax Application: Schritt 3, Bild 1 von 1
    • Wipe the skis with a towel, removing dirt, excess wax, the base cleaner, and dust.
  4. Alpine Ski Wax Application: Schritt 4, Bild 1 von 1
    • Spread wax across the base of the ski with an edge to edge motion. While doing this hold the iron perpendicular to the base and press the wax into the iron.
    • Be careful when handling the hot iron and the hot wax.
  5. Alpine Ski Wax Application: Schritt 5, Bild 1 von 1
    • Melt the wax into the base using a tip to tail stroke with the iron.
    • Let the skis dry for at least 30 minutes once all the wax is melted.
  6. Alpine Ski Wax Application: Schritt 6, Bild 1 von 1
    • Scrape the excess wax off with the plastic scraper. Continue this process until there is no visible wax on the ski base.
  7. Alpine Ski Wax Application: Schritt 7, Bild 1 von 1
    • Scrape the excess wax off of the side of the ski.
  8. Alpine Ski Wax Application: Schritt 8, Bild 1 von 1
    • Wipe the fine wax dust from the ski base.
Ziellinie
Evan Gornick
101 Reputation
1 Anleitung geschrieben
Michigan Tech, Team S5-G4, Galliah Fall 2017 Mitglied von Michigan Tech, Team S5-G4, Galliah Fall 2017
MTU-GALLIAH-F17S5G4
2 Mitglieder
2 Anleitungen geschrieben
8 Kommentare
Very nice post! That's a great website I have visited, thank you for your essentials words run 3
Martin Tolley - Antwort
I read your article very detailed and easy to understand, I hope next time you will have more wonderful articles to share with the reader.
run 3
switch color - Antwort
thansks for the post
Arun nagar - Antwort
'''WYSIWYG Web Builder Crack''' has a unique and easy to use tools for both beginners and professional developers. Hence it is straightforward to use application.
Harry Oscar - Antwort
I really enjoy the blog article. Much thanks again. Want more.
Wondershare Filmora Scrn Crack
DxO PhotoLab Crack
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 402
