Zum Hauptinhalt wechseln
Altec Lansing BoomJacket 2 Motherboard Replacement
Was du brauchst
  1. Altec Lansing BoomJacket 2 Motherboard Replacement, Altec Lansing BoomJacket 2 Disassembly: Schritt 1, Bild 1 von 2 Altec Lansing BoomJacket 2 Motherboard Replacement, Altec Lansing BoomJacket 2 Disassembly: Schritt 1, Bild 2 von 2
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Motherboard Replacement: Schritt 2, Bild 1 von 2 Altec Lansing BoomJacket 2 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Motherboard Replacement: Schritt 4, Bild 1 von 2 Altec Lansing BoomJacket 2 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Gently pull apart the front panel from the base of the speaker.
  7. Altec Lansing BoomJacket 2 Motherboard Replacement, Battery: Schritt 7, Bild 1 von 1
    • The battery will be in the middle of the speaker when the case is open.
  8. Altec Lansing BoomJacket 2 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Pull firmly from both sides of the pin to disconnect the battery cable from the motherboard.
    • Pull battery up and away from speaker without catching any other components.
    • Motherboards have fragile components and can easily be damaged if they are hit or pulled on while extracting other parts.
  9. Altec Lansing BoomJacket 2 Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 2 Altec Lansing BoomJacket 2 Motherboard Replacement, Motherboard: Schritt 9, Bild 2 von 2
    • Disconnect the furthest right hand plug first.
    • Do not pull from the wires. Pull from the white connector.
  10. Altec Lansing BoomJacket 2 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Gently pull the motherboard directly upwards to avoid damage.
    • Be sure to lift slowly.
  11. Altec Lansing BoomJacket 2 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Disconnect the remaining connectors from the motherboard.
    • Do not forcefully pull connectors. Pull from the connectors, not from the wires.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Zach Braaten
516 Reputation
4 Anleitungen geschrieben
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Mitglied von UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
4 Mitglieder
Ein Kommentar
Where is the best place to purchase a motherboard for the Altec Lansing Jacket H20 4?
Kelvin Jasper - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 838
