Einleitung
If the speaker sound quality is distorted or quiet you can follow this guide to replace the defective speaker.
Was du brauchst
Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
Using your fingers, grab the blue sleeve from one side and pull away from the unit.
At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
Unscrew the two screws on the smaller speaker.
Pull the small speaker through the larger speaker hole.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
