Zum Hauptinhalt wechseln
Altec Lansing BoomJacket Battery Replacement
Was du brauchst
  1. Altec Lansing BoomJacket Battery  Replacement, Case Removal: Schritt 1, Bild 1 von 1
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Altec Lansing BoomJacket Battery  Replacement: Schritt 2, Bild 1 von 1
    • Remove the outer black rubber housing of the speaker.
  3. Altec Lansing BoomJacket Battery  Replacement: Schritt 3, Bild 1 von 1
    • Remove the inner blue rubber housing from the speaker.
  4. Altec Lansing BoomJacket Battery  Replacement: Schritt 4, Bild 1 von 1
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Altec Lansing BoomJacket Battery  Replacement: Schritt 5, Bild 1 von 2 Altec Lansing BoomJacket Battery  Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Altec Lansing BoomJacket Battery  Replacement: Schritt 6, Bild 1 von 1
    • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
  7. Altec Lansing BoomJacket Battery  Replacement: Schritt 7, Bild 1 von 1
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Altec Lansing BoomJacket Battery  Replacement, Battery: Schritt 8, Bild 1 von 1
    • The battery will be sitting right behind the speakers when the case is open.
  9. Altec Lansing BoomJacket Battery  Replacement: Schritt 9, Bild 1 von 1
    • Unplug and disconnect the battery from the motherboard.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
Where can you buy a replacement battery?
Darrell riley - Antwort
Where can you buy the battery please?
Juan Roa - Antwort
Where can I find ghe batteries? What type of battery ?
Violet Roach - Antwort
where ca i buy a replacement battery
Shelley Franck - Antwort
This tutorial is incomplete.
Ivan Rodriguez - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 24
Letzte 30 Tage: 80
Insgesamt: 14,610
