Einleitung
Does your speakers bluetooth not seem to be connecting or dropping connections? The bluetooth board could be the cause.
Was du brauchst
Using your hands, remove the pegs (4+4) from the front and back of the speaker.
Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
Pull the case apart and you will be able to see all the components inside the speaker.
Now that the case is open look for the small green (NFC) chip on the inside of the case next to the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
