Einleitung
Are you trying to repair a part inside your speaker but need to first remove the case that surrounds the speakers? This guide will help you do just that!
Was du brauchst
Using your hands, remove the pegs (4+4) from the front and back of the speaker.
Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
Pull the case apart and you will be able to see all the components inside the speaker.
