Zum Hauptinhalt wechseln
Altec Lansing BoomJacket Speaker Replacement
Was du brauchst
  1. Altec Lansing BoomJacket Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Altec Lansing BoomJacket Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the outer black rubber housing of the speaker.
  3. Altec Lansing BoomJacket Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove the inner blue rubber housing from the speaker.
  4. Altec Lansing BoomJacket Speaker Replacement: Schritt 4, Bild 1 von 1
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Altec Lansing BoomJacket Speaker Replacement: Schritt 5, Bild 1 von 2 Altec Lansing BoomJacket Speaker Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Altec Lansing BoomJacket Speaker Replacement: Schritt 6, Bild 1 von 1
    • Using the size PH1 screwdriver remove the screws (4 around each speaker).
  7. Altec Lansing BoomJacket Speaker Replacement: Schritt 7, Bild 1 von 1
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Altec Lansing BoomJacket Speaker Replacement: Schritt 8, Bild 1 von 1
    • Remove the speakers (not entirely because of the wiring) by gently pulling each speaker up.
Abschluss
2 Kommentare
Where do I find the correct part to replace the charging port on my boom jacket?
Rockstar - Antwort
1.1" External Magnetic Type Round Slim Plastic Shell Speaker 8 Ohm 0.25W 2 Pcs
Eeshton -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 754
