Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
If your Altec Lansing Mini Lifejacket 2's aux input or power jack is faulty or damaged, this guide will show you how to replace the back panel of your device.
  1. Use the spudger to remove the eight black pins from the front and back of the wire screens. Use the spudger to remove the eight black pins from the front and back of the wire screens. Use the spudger to remove the eight black pins from the front and back of the wire screens.
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger. Removing the secondary pins from the rubber casing is optional. Removing the secondary pins from the rubber casing is optional.
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Remove both black and orange layers from the speaker body. Remove both black and orange layers from the speaker body.
    • Remove both black and orange layers from the speaker body.
  4. Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device. Slide the mounting plate out to remove it. Slide the mounting plate out to remove it.
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Pry off the wire mesh on both sides using a metal spudger. Be gentle to avoid bending the mesh.
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Using tweezers, remove the four rubber stoppers in each corner of the rear panel. Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Pull the case apart to access the interior components.
    • Pull the case apart to access the interior components.
  9. To remove the back panel, gently pull out its wire harness. To remove the back panel, gently pull out its wire harness. To remove the back panel, gently pull out its wire harness.
    • To remove the back panel, gently pull out its wire harness.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Stephen Albrecht
782 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S3-G2, Nance Spring 2018 Mitglied von USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Mitglieder
What do I replace once I have it apart? Where's the charging port? How do I get another charging port that works?
Ggs - Antwort
The charging port and the aux input are mounted to a circuit board enclosed within a small compartment on the back panel. We didn’t open the compartment in this guide because it requires breaking the seal of the compartment’s gasket, which would be unreasonable to replace. We figured it would be easier to replace the whole back panel instead. My advice for finding a new charging port would be to scour eBay or a similar site for a broken Mini Lifejacket and use its entire back panel as the replacement.
Stephen Albrecht -
can you charge it with an ac adapter like through the aux port?
Naomi - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 5
Letzten 7 Tage: 63
Letzten 30 Tage: 288
Insgesamt: 4,433
