Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to replace the motherboard in your Altec Lansing Mini Lifejacket 2 if the bluetooth chip, microphone, or another electronic component has failed.
  1. Use the spudger to remove the eight black pins from the front and back of the wire screens. Use the spudger to remove the eight black pins from the front and back of the wire screens. Use the spudger to remove the eight black pins from the front and back of the wire screens.
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger. Removing the secondary pins from the rubber casing is optional. Removing the secondary pins from the rubber casing is optional.
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Remove both black and orange layers from the speaker body. Remove both black and orange layers from the speaker body.
    • Remove both black and orange layers from the speaker body.
  4. Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device. Slide the mounting plate out to remove it. Slide the mounting plate out to remove it.
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Pry off the wire mesh on both sides using a metal spudger. Be gentle to avoid bending the mesh.
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Using tweezers, remove the four rubber stoppers in each corner of the rear panel. Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Pull the case apart to access the interior components.
    • Pull the case apart to access the interior components.
  9. To remove the back panel, gently pull out its wire harness. To remove the back panel, gently pull out its wire harness. To remove the back panel, gently pull out its wire harness.
    • To remove the back panel, gently pull out its wire harness.
  10. Disconnect the battery from the motherboard. The battery is not secured within the case and can be removed after detaching its wiring from the circuit board. The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
  11. Unplug the remaining four wire harnesses attached to the circuit board Unplug the remaining four wire harnesses attached to the circuit board Unplug the remaining four wire harnesses attached to the circuit board
    • Unplug the remaining four wire harnesses attached to the circuit board
  12. Remove the three 9.1mm Phillips #1 screws located on the circuit board. Remove the three 9.1mm Phillips #1 screws located on the circuit board.
    • Remove the three 9.1mm Phillips #1 screws located on the circuit board.
  13. Remove the motherboard. Remove the motherboard. Remove the motherboard.
    • Remove the motherboard.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Stephen Albrecht
869 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S3-G2, Nance Spring 2018 Mitglied von USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Mitglieder
I own the IMW778-BLU-TA model. Where can I find a replacement motherboard for it??
Nick Cote - Antwort
same for me, anyone knows where can I find a replacement of the motherboard? thx
Travis - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 4
Letzten 7 Tage: 24
Letzten 30 Tage: 98
Insgesamt: 3,309
