Zum Hauptinhalt wechseln
Altec Lansing VersA Smart Volume Button Board Replacement
Was du brauchst
  1. Altec Lansing VersA Smart Volume Button Board Replacement, External Panels: Schritt 1, Bild 1 von 1
    • Remove external rubber cover.
  2. Altec Lansing VersA Smart Volume Button Board Replacement: Schritt 2, Bild 1 von 2 Altec Lansing VersA Smart Volume Button Board Replacement: Schritt 2, Bild 2 von 2
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Altec Lansing VersA Smart Volume Button Board Replacement: Schritt 3, Bild 1 von 2 Altec Lansing VersA Smart Volume Button Board Replacement: Schritt 3, Bild 2 von 2
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Altec Lansing VersA Smart Volume Button Board Replacement: Schritt 4, Bild 1 von 1
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
  5. Altec Lansing VersA Smart Volume Button Board Replacement, Volume Button Board: Schritt 5, Bild 1 von 2 Altec Lansing VersA Smart Volume Button Board Replacement, Volume Button Board: Schritt 5, Bild 2 von 2
    • Orient speaker so volume buttons are facing up.
    • Remove rubber button piece using the blue plastic opening tool.
  6. Altec Lansing VersA Smart Volume Button Board Replacement: Schritt 6, Bild 1 von 2 Altec Lansing VersA Smart Volume Button Board Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 9mm screws using the Torx T5 screwdriver.
  7. Altec Lansing VersA Smart Volume Button Board Replacement: Schritt 7, Bild 1 von 2 Altec Lansing VersA Smart Volume Button Board Replacement: Schritt 7, Bild 2 von 2
    • Once screws are removed, remove the plastic covering piece.
    • Remove the rubber piece below the plactic covering piece to expose the daughterboard.
  8. Altec Lansing VersA Smart Volume Button Board Replacement: Schritt 8, Bild 1 von 2 Altec Lansing VersA Smart Volume Button Board Replacement: Schritt 8, Bild 2 von 2
    • Orient speaker on its side with volume buttons facing away from you and Bluetooth and power buttons on the right.
    • Detach the wiring, located in the upper middle section of the motherboard.
    • Remove daughterboard piece from opening in the top of the speaker.
Abschluss
Rachael Hopp
550 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 425
