Zum Hauptinhalt wechseln
Aluratek ADMPF310F Motherboard Replacement
Was du brauchst
  1. Aluratek ADMPF310F Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Aluratek ADMPF310F Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Aluratek ADMPF310F Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Using the black nylon spudger, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Lift screen out of place so you can access the plugs that connect it.
  3. Aluratek ADMPF310F Motherboard Replacement: Schritt 3, Bild 1 von 2 Aluratek ADMPF310F Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the mother board.
    • Be careful as this zif connector is very frail plastic.
  4. Aluratek ADMPF310F Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Pull out remote receiver out of its clip.
    • Be careful to not move the wires around for the remote receiver too much, as they are soldered to the motherboard.
  6. Aluratek ADMPF310F Motherboard Replacement: Schritt 6, Bild 1 von 2 Aluratek ADMPF310F Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Using fingers pull the first speaker wire that is located closest to the speakers
    • Again using your fingers, pull out the second speaker wire near the far side of the motherboard.
  7. Aluratek ADMPF310F Motherboard Replacement: Schritt 7, Bild 1 von 3 Aluratek ADMPF310F Motherboard Replacement: Schritt 7, Bild 2 von 3 Aluratek ADMPF310F Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Using the ph0 phillips head screwdriver unscrew the four 4mm screws circled in the picture.
  8. Aluratek ADMPF310F Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Pull up the smaller end of the motherboard.
    • Apply force pulling away from the USB ports to get the mother board out of place.
Abschluss
Pascal Alexis
427 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 5-1, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 552
