Zum Hauptinhalt wechseln
Aluratek ADMPF310F Screen Replacement
Was du brauchst
  1. Aluratek ADMPF310F Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Aluratek ADMPF310F Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Aluratek ADMPF310F Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Screen Replacement: Schritt 2, Bild 1 von 1
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Screen Replacement: Schritt 3, Bild 1 von 2 Aluratek ADMPF310F Screen Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the motherboard.
    • Be careful as this clip is very frail.
  4. Aluratek ADMPF310F Screen Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
Abschluss
Chris Belair
333 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 5-1, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 406
