Zum Hauptinhalt wechseln
Aluratek ADMPF310F Speakers Replacement
Was du brauchst
  1. Aluratek ADMPF310F Speakers Replacement, Speakers: Schritt 1, Bild 1 von 3 Aluratek ADMPF310F Speakers Replacement, Speakers: Schritt 1, Bild 2 von 3 Aluratek ADMPF310F Speakers Replacement, Speakers: Schritt 1, Bild 3 von 3
    • Using the plastic opening tool pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Speakers Replacement: Schritt 2, Bild 1 von 1
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Speakers Replacement: Schritt 3, Bild 1 von 2 Aluratek ADMPF310F Speakers Replacement: Schritt 3, Bild 2 von 2
    • Unplug both plugs for the speakers to the motherboard
  4. Aluratek ADMPF310F Speakers Replacement: Schritt 4, Bild 1 von 2 Aluratek ADMPF310F Speakers Replacement: Schritt 4, Bild 2 von 2
    • Use plastic opening tool to pull out one of the speakers.
    • Then use your hand to take out the other speaker
  5. Aluratek ADMPF310F Speakers Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the wires off of the old speakers and solder the old wires onto the new speakers.
Abschluss
Chris Belair
333 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 5-1, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 105
