Zum Hauptinhalt wechseln
Amana Freestanding Electric Range Burners and Rims Replacement
Was du brauchst
    1. Amana Freestanding Electric Range Burners and Rims Replacement, Stove Burners and Rims: Schritt 1, Bild 1 von 3 Amana Freestanding Electric Range Burners and Rims Replacement, Stove Burners and Rims: Schritt 1, Bild 2 von 3 Amana Freestanding Electric Range Burners and Rims Replacement, Stove Burners and Rims: Schritt 1, Bild 3 von 3
      • Turn the knob for the desired burner to full heat.
      • If there is an unusual amount of heat or no heat, continue.
      Frag FixBot
      Kommentar hinzufügen
    2. Amana Freestanding Electric Range Burners and Rims Replacement: Schritt 2, Bild 1 von 3 Amana Freestanding Electric Range Burners and Rims Replacement: Schritt 2, Bild 2 von 3 Amana Freestanding Electric Range Burners and Rims Replacement: Schritt 2, Bild 3 von 3
      • Turn off the burner and let it cool.
      • Remove the burner after it has cooled by grabbing the edge and carefully pulling the element at a slight upward angle.
      Frag FixBot
    3. Amana Freestanding Electric Range Burners and Rims Replacement: Schritt 3, Bild 1 von 1
      • Clean the burner element end with a wire brush or a metal sponge.
      Frag FixBot
    4. Amana Freestanding Electric Range Burners and Rims Replacement: Schritt 4, Bild 1 von 2 Amana Freestanding Electric Range Burners and Rims Replacement: Schritt 4, Bild 2 von 2
      • Take one end of the element and bend it by 3.2 mm to make better contact with the socket inside.
      Frag FixBot
    5. Amana Freestanding Electric Range Burners and Rims Replacement: Schritt 5, Bild 1 von 2 Amana Freestanding Electric Range Burners and Rims Replacement: Schritt 5, Bild 2 von 2
      • Place the new burner rim in the space with the hole for the element.
      • Make sure it is aligned with the socket.
      Frag FixBot
    6. Amana Freestanding Electric Range Burners and Rims Replacement: Schritt 6, Bild 1 von 2 Amana Freestanding Electric Range Burners and Rims Replacement: Schritt 6, Bild 2 von 2
      • Gently push the restored element through the hole into the socket.
      Frag FixBot
    7. Amana Freestanding Electric Range Burners and Rims Replacement: Schritt 7, Bild 1 von 1
      • Turn the knob to full heat after all steps are completed to test that it is working.
      Frag FixBot
Abschluss
Refer to guides on repairing electrical components of electric stove burners or seek professional help if the guide does not help solve the problem.
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 130
Insgesamt: 2,121
