Zum Hauptinhalt wechseln
Amana NGD4655EW1 Dryer Door Handle Replacement
Was du brauchst
  1. Amana NGD4655EW1 Dryer Door Handle Replacement, Door Handle: Schritt 1, Bild 1 von 2 Amana NGD4655EW1 Dryer Door Handle Replacement, Door Handle: Schritt 1, Bild 2 von 2
    • Clean the area around the door handle with a cloth.
  2. Amana NGD4655EW1 Dryer Door Handle Replacement: Schritt 2, Bild 1 von 1
    • Position the door handle replacement where it suits you best.
    • Use a level to make sure the door handle is straight and neat.
  3. Amana NGD4655EW1 Dryer Door Handle Replacement: Schritt 3, Bild 1 von 2 Amana NGD4655EW1 Dryer Door Handle Replacement: Schritt 3, Bild 2 von 2
    • Use a marker to mark where the four screws are going to be placed.
  4. Amana NGD4655EW1 Dryer Door Handle Replacement: Schritt 4, Bild 1 von 2 Amana NGD4655EW1 Dryer Door Handle Replacement: Schritt 4, Bild 2 von 2
    • Place the point of a center punch in the middle of a mark.
    • Take a rubber mallet and lightly hit the top of the center punch to make an indentation in the dryer door.
    • Repeat this process for the other three marks.
  5. Amana NGD4655EW1 Dryer Door Handle Replacement: Schritt 5, Bild 1 von 2 Amana NGD4655EW1 Dryer Door Handle Replacement: Schritt 5, Bild 2 von 2
    • Use a 1/4" nut driver to drive the Tek screws into the four indentations.
    • Be sure to sweep up and dispose of any metal shavings before moving on.
  6. Amana NGD4655EW1 Dryer Door Handle Replacement: Schritt 6, Bild 1 von 3 Amana NGD4655EW1 Dryer Door Handle Replacement: Schritt 6, Bild 2 von 3 Amana NGD4655EW1 Dryer Door Handle Replacement: Schritt 6, Bild 3 von 3
    • Line up the holes in your new handle with the holes in the dryer door.
    • Screw the Tek screws in the holes previously made, securing the handle into the dryer door.
Abschluss
You should now have a fully functional door handle for your Amana dryer machine!
Oniel A. Plaza
133 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 28
Insgesamt: 623
