Zum Hauptinhalt wechseln
Amazon Echo Dot 2nd Generation Ribbon Cable Replacement
Was du brauchst
  1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: Schritt 1, Bild 1 von 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: Schritt 1, Bild 2 von 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: Schritt 1, Bild 3 von 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 2, Bild 1 von 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 2, Bild 2 von 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 2, Bild 3 von 3
    • Use a T8 screwdriver bit to unscrew the 1.6mm four screws.
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 3, Bild 1 von 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 3, Bild 2 von 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 3, Bild 3 von 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 4, Bild 1 von 1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 5, Bild 1 von 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 5, Bild 2 von 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 5, Bild 3 von 3
    • Remove the silver divider
    • Remove the black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 6, Bild 1 von 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 6, Bild 2 von 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: Schritt 6, Bild 3 von 3
    • Remove the ribbon cable from the slot on the LED/speaker board
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S1-G3, Leahy Fall 2017 Mitglied von USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Mitglieder
12 Anleitungen geschrieben
5 Kommentare
Where do you get the replacement cable from?
jonathan kabitzke - Antwort
Yes, where can one get replacement ribbon cables?
Armando Morreale - Antwort
Malcolm oakley - Antwort
I need a replacement as well now was using a pointed tweezers when putting it back together and stabbed the cable need to find part and order from the uk
Barrie Gash - Antwort
no cable available, just waiting for donors
Ray Floyd Cabrera - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 2,460
