Zum Hauptinhalt wechseln
Einleitung
Use this guide to remove and replace the speaker in the Amazon Echo Dot 2nd Generation.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Power off and unplug the echo Using the plastic opening tool, peel off the rubber layer on the bottom of the echo Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws Remove the black, cylindrical base Remove the black, cylindrical base
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black, cylindrical base
  3. Tap the base against the palm of your hand so that the black speaker component comes out
    • Tap the base against the palm of your hand so that the black speaker component comes out
Abschluss
9 weitere Nutzer haben diese Anleitung absolviert.
Alexis White
396 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S1-G3, Leahy Fall 2017 Mitglied von USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Mitglieder
10 Anleitungen geschrieben
Where can one purchase the replacement speaker component?
ananomaus - Antwort
Can you inform us were to get replacement speaker please.
John Stead - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 4
Letzten 7 Tage: 21
Letzten 30 Tage: 105
Insgesamt: 8,402
