Was du brauchst
When Prying the bottom off, insert the Metal Spudger under the bottom where the ports are
Avoid letting the Adhesive touch anything, lay the plate on the branded side
If the adhesive is to strong use a hair dryer to soften it
Use a TORX T6H bit to remove the four screws on the bottom
When all the screws are taken out lift up and the covering should slide off
Remember to un latch the ribbon cable before pulling the circuit board up
To get the further screws on the bottom, use a 4 mm nut driver and put the TORX bit in the nut driver as an extension
Pull up on the metal to release the top from the rest
Undo the four screws the remove the white defuser piece (I lost a screw)
The two should separate if you hold the edge, if it doesn't push a button on top and it should pop out
4 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Parabéns pelo tutoria de desmontagem do aparelho ALEXA ECHO DOT 3ª geração! Excelente trabalho!!!
Eu recebi um aparelho desse para efetuar a manutenção, pois este estavatotalmente inoperante, por dois motivos:
1° ADAPTADOR FONTE AVARIADO, gerando tensão de saída DC oscilante;
2° MAL-CONTATO NO CABO FLEXÍVEL INTERNO que conecta as duas placas eletrônicas internas.
How can I convert Amazon Echo Dot power from AC to DC?
