Einleitung
The Amazon Echo Look's primary function as a fashion assistant can be affected if the Wi-Fi module is damaged. The device uses Wi-Fi in order to use its main features such as looking for wardrobes; a damaged Wi-Fi module can hinder that.
Was du brauchst
Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
If the device stand is attached, remove it by twisting the device's base toward yourself until detached.
Heat the front panel with an iOpener.
Heat the device for 5-10 minutes to loosen the glue.
Lever the Jimmy between the screen and the device until an opening is formed.
Insert opening picks to hold the opening as needed.
Use a spudger to circle the border of the front panel and disconnect any lingering glue.
Remove the screws from the midframe with a Torx T5 screwdriver.
Lift up the midframe
Remove the eight screws attached to the gray metal piece using a Torx T5 screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
