Einleitung
This is a step-by-step guide to show how to remove the circuit board that is attached to the speakers. It can be done in just a few simple steps with the help of a spudger and a few screw drivers.
Was du brauchst
Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
Pull each of the plugs out.
Use the metal spudger to pry and create space between the sound foam and the frame.
Once you have sufficiently pried the foam from the frame on each side, detach the sound foam from the frame with your hands.
Unscrew the white case using the TR1 screwdriver bit to remove the 4mm screws.
Pull on the top until the case becomes fully dislodged.
Pull out the two white plugs by firmly grasping them and pulling in a downward motion until they become disconnected.
Unscrew the 4mm, red-marked screws with the TR6 screwdriver bit.
Detach the ribbon from the circuit board by grasping from the top of the ribbon and pulling away from the board.
Unscrew the red-marked, 4mm screws with the J1 screwdriver bit.
Carefully slide the sound card up and out of the black casing.
