Zum Hauptinhalt wechseln
Amazon Echo Show 2nd Gen Sound foam Replacement
Was du brauchst
  1. Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: Schritt 1, Bild 1 von 3 Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: Schritt 1, Bild 2 von 3 Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: Schritt 1, Bild 3 von 3
    • Make sure the device is unplugged and powered off.
    • Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
    • Pull each of the plugs out.
  2. Amazon Echo Show 2nd Gen Sound foam Replacement: Schritt 2, Bild 1 von 3 Amazon Echo Show 2nd Gen Sound foam Replacement: Schritt 2, Bild 2 von 3 Amazon Echo Show 2nd Gen Sound foam Replacement: Schritt 2, Bild 3 von 3
    • Use the metal spudger to pry and create space between the sound foam and the frame.
    • Once you have sufficiently pried the foam from the frame on each side, detach the sound foam from the frame with your hands.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 1,762
